Replace non-PoE Power supply in 2811 with PWR-2811-AC-IP=?
Answered Question
Jun 26th, 2008
I have a customer with the standard AC power supply in a 2811. Can I simply order the spare PWR-2811-AC-IP= so that I can get PoE in the chassis and swap the power supplies? I want to make sure that I have all of the system board connections and cables necessary to do this. Thanks.
Correct Answer by lagos about 8 years 11 months ago
I've done this and is very straightforward. The part will contain everything you need including a pigtail that connects -48V from the PS directly to the motherboard.
HTH!
Overall Rating: 5 (1 ratings)
paolo bevilacqua Fri, 06/27/2008 - 03:12
  • Hall of Fame,
    Founding Member
That will be enougn for PoE PS. Then, also some the ESW cards come in varieties with or without PoE, so you've to chekc what's installed in the router also. Use "show diag" for that.
Correct Answer
lagos Fri, 06/27/2008 - 03:43
  • Cisco Employee,
HTH!
