RTMT "Unable to restore configuration. Host name is not define on DB"
Jun 26th, 2008
Tonight we moved our Publisher and Subscriber to a new location and also we had to changed their ip's.
We are experiencing a problem with RTMT.
When i log in to RTMT i get the error "Unable to restore configuration. Host name in the configuration is not on DB"
Please help,
Thanks.
Zeek
Overall Rating: 5 (1 ratings)
Jaime Valencia Fri, 06/27/2008 - 05:56
  • Cisco Employee,
  • Hall of Fame,
    2011
what version?
CSCee76271
Cannot restore some profile saved
1) From the CCMAdmin web page, select Service then Service Parameters
2) Specify the CallManager server and select RIS Data Collector
3) Ensure that "Data Collection Enabled" is set to True
4) Verify the Primary Collector, must be the hostname of the server (PUB recommended) where you installed RTMT
javalenc
if this helps, please rate
descashared Tue, 11/17/2009 - 07:13
Hi Javalenc
i'm having the exact same issue, just that under service parameters of RIS data collector i cannot see the data collection enabled parameter. in my case i have upgraded from ccm 4.1 to ccm 6.1.4
bsugamele1 Thu, 02/09/2012 - 07:56
I just ran into this same error after changing the IP address of a subscriber server. I have verified that data collection enabled is set to true on the CUCM server I changed the IP on. I'm not sure how to verfiy the Primary collector though.
Any other thoughts? I am actually still getting alerts from the old IP address that the server is down etc.
Thanks!
Brett
