regular translation creation failed for protocol 50 src inside
Jun 26th, 2008
Hi, one of inside user are not able to connect with servers through remote VPN. And when I use clear xlate command then it works but after some time same issue happens. After inspection the logs then I found the following error.
Please suggest, Thanks
a.alekseev Thu, 06/26/2008 - 23:58
I can guess that you are doing PAT on your PIX/ASA/Router.
But you cannot use PAT for ESP (protocol 50).
ray_stone Fri, 06/27/2008 - 00:52
yeah... you are right we are using PAT. So is there any solution to resolve this issue...Thansk
