06-26-2008 10:06 PM - edited 03-03-2019 10:31 PM
Router where i try to redistribute from BGP into OSPF -
interface Loopback0
ip address 172.22.21.104 255.255.255.255
interface GigabitEthernet0/0
description ### Int to AS65337 ###
ip address 9.9.9.2 255.255.255.248
ip ospf network non-broadcast
ip ospf dead-interval minimal hello-multiplier 10
ip ospf priority 0
duplex auto
speed auto
media-type rj45
router ospf 1
log-adjacency-changes
redistribute bgp 65334 subnets
network 9.9.9.0 0.0.0.7 area 0
router bgp 65334
no synchronization
bgp log-neighbor-changes
network 10.50.12.0 mask 255.255.252.0
network 10.60.12.0 mask 255.255.252.0
network 172.22.21.104 mask 255.255.255.255
neighbor 1.1.1.201 remote-as 65334
neighbor 1.1.1.201 next-hop-self
neighbor 1.1.1.201 soft-reconfiguration inbound
neighbor 1.1.1.201 filter-list 1 out
no auto-summary
Second router is neighbor via OSPF
interface Vlan1
ip address 9.9.9.1 255.255.255.248
router ospf 1
redistribute connected metric-type 1 subnets
neighbor 9.9.9.2
neighbor 9.9.9.3
maximum-paths 1
#sh ip ospf ne
Neighbor ID Pri State Dead Time Address Interface
172.22.21.104 0 FULL/DROTHER 941 msec 9.9.9.2 Vlan1
172.22.21.105 0 FULL/DROTHER 908 msec 9.9.9.3 Vlan1
and got next routes from 9.9.9.2
#sh ip route ospf
172.22.0.0/32 is subnetted, 2 subnets
O E2 172.22.21.104 [110/1] via 9.9.9.2, 00:01:25, Vlan1
But router 9.9.9.2 have a lot routes got via bgp -
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
1.1.1.201 4 65334 17455 13044 207288 0 0 1d00h 161
and redistribute into ospf only route
172.22.21.104/32?
Why it is so?
Solved! Go to Solution.
06-26-2008 11:28 PM
If you want to redistribute iBGP routes into OSPF, you need to configure "bgp redistribute-internal " in bgp routing process.
06-26-2008 10:55 PM
It shows to have learnt 161 prefixes from IBGP neighbor. Can you see the outpu of " sh bgp neighbor 1.1.1.201 received-routes".
If feasible, do a soft-reset of neighbor. & verify again.
06-26-2008 11:12 PM
1.1.1.201 is IBGP neighbor and i can see all 161 prefixes-
#sh bgp neighbor 1.1.1.201 received-routes
BGP table version is 216648, local router ID is 172.22.21.104
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
r>i1.1.1.0/24 1.1.1.201 0 100 0 ?
*>i2.2.2.0/24 172.22.22.2 2 100 0 ?
*>i3.3.3.0/30 172.22.21.100 0 100 0 i
*>i5.5.5.0/30 172.22.23.2 0 100 0 i
*>i5.5.5.4/30 1.1.1.201 0 100 0 i
*>i5.5.5.8/30 1.1.1.201 0 100 0 i
*>i10.0.0.0/24 172.22.23.2 0 100 0 i
*>i10.10.16.0/24 172.22.23.2 0 100 0 2854 65011 i
*>i10.10.18.0/24 172.22.23.2 0 100 0 2854 65003 i
*>i10.10.22.0/24 172.30.0.66 0 100 0 3216 65415 i
*>i10.10.26.0/24 172.22.23.2 0 100 0 2854 65006 i
*>i10.10.28.0/24 172.22.23.2 0 100 0 2854 65009 i
*>i10.10.30.0/24 172.22.23.2 0 100 0 2854 65012 i
*>i10.10.34.0/24 172.30.0.66 0 100 0 3216 65411 i
*>i10.10.35.0/24 172.30.0.66 0 100 0 3216 65411 i
*>i10.10.36.0/24 172.22.23.2 0 100 0 2854 65007 i
*>i10.10.38.0/24 172.22.23.2 0 100 0 2854 65008 i
*>i10.10.42.0/24 172.22.23.2 0 100 0 2854 65005 i
*>i10.10.46.0/24 10.20.46.2 0 100 0 i
*>i10.10.48.0/24 172.22.23.2 0 100 0 2854 65010 i
*>i10.10.49.0/24 172.22.23.2 0 100 0 2854 65014 i
*>i10.10.140.32/30 172.22.23.2 0 100 0 i
06-26-2008 11:16 PM
Do you think the reason that redistribution don't work because routes got from IBGP neighbor?
06-26-2008 11:28 PM
