CME "CFA Rules" ?
Jun 26th, 2008
Quick question. Is is possible to allow a user to dial a number, but block him from CFA to the same number. For Example: A user is allowed to call Mobile numbers, but is not supposed to CFA to a Mobile numbers. Anyone try this?
kumar3880 Fri, 06/27/2008 - 03:43
hi i suppose we can assign a CSS to the CFA so tht calls may not be forwarded any numbers outside the CSS.
regards
kumars
paolo bevilacqua Fri, 06/27/2008 - 03:47
  • Hall of Fame,
    Founding Member
Kumar,
the question is about CME, not CM, so CSS do not apply.
Fulcherke, if you're trying to prevent call-forward to external numbers, the easier way is to limit tha maximum number of digits. You can do that with "call-forward max-length" under ephone-dn-template.
Keith Fulcher Fri, 06/27/2008 - 03:54
Not really to external numbers, but to specific numbers. Normally I would agree with your assessment about the Max number of digits. However, this is a SRST CME for a large company with a long internal number plan. In Germany (where I am at) there is not a set 10 digit number dial plan, so I can not set a max-number without colliding with the users right to CFA Internally. Is there such a thing as Cor lists that can be applied to CFA? I know this is an off the wall question, but I figured someone might have tried it out.
paolo bevilacqua Fri, 06/27/2008 - 03:58
  • Hall of Fame,
    Founding Member
It may be a bit complicated to do that.
The reason is because I think the "transfer-pattern" command do not apply to CF.
I will revert back to you once I can suggest a solution.
