Outgoing calls issue
Jun 27th, 2008
*Jun 27 10:19:53.715: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 0113252322
*Jun 27 10:19:53.719: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 0119129300
*Jun 27 10:19:53.747: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 73 changed to up
*Jun 27 10:19:53.747: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x13
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Calling Party Number i = 0x0080, '0113252322'
Plan:Unknown, Type:Unknown
*Jun 27 10:19:53.851: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x93
Cause i = 0x82C1 - Bearer capability not implemented
Any ideas? Let me know if you want the config, thanks
Overall Rating: 5 (5 ratings)
pcameron Sun, 06/29/2008 - 04:33
  • Cisco Employee,
The problem is due to this -
This means the call is using ulaw coding and I would guess you are not located in North America.
Add the following command under voice-port 0/1/0
compand-type a-law
I would also suggest you add the following commands (in case you don't already have them) to ensure the DSP's are clocked off the BRI port -
network-clock-participate wic 0
network-clock-select 1 bri 0/1/0
This will fix faxing or modem issues that you may never know you had :-)
paolo bevilacqua Sun, 06/29/2008 - 09:24
  • Hall of Fame,
    Founding Member
Missed this one .. 5 points to Paul for combining two all-time favorites in a single answer :)
shaunswales Sun, 06/29/2008 - 21:51
Yeah! Thanks okes, umm... 5 to you! Thanks, am going to test now. Will post results...
shaunswales Sun, 06/29/2008 - 23:17
Yip, executed the changes and also had to put the progree indicator and progress alerting on, am now able to make outgoing calls, however need to implement CoR now :)
