Cannot delete partition from callmanager 4.2
Answered Question
Jun 27th, 2008
I've created some class of control -> partition. Then i've assinged several phones to this partition. Then i've removed this partition from these phones. But when i try to delete this partition, it says that there are some devices associated with it. Dependency records show those phones. But i'm sure that the Partition drop-down menu is set to NONE on these phones.
What should i do, how to delete this god damned partition?
Correct Answer by Jaime Valencia about 8 years 11 months ago
make sure to delete all unassigned DNs, maybe one ot those is using that partition
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 06/27/2008 - 05:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Oleg,
I looked for bugs related to this issue but can't find any in 4.2 Can you delete the phones and also remove them from the Route Plan >Unassigned DN's then remove the Partition (then rebuild the phones). I'm sure this is not what you want to do but I'm sure that this will work.
Hope this helps!
Rob
Correct Answer
Jaime Valencia Fri, 06/27/2008 - 06:20
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
