Small network with 2 router and 42 layer 2 switches
Jun 27th, 2008
I have 2 router with 2 WIC 2 T & HWIC 4 T
1st router will connect to 2 deferent ISP with connection 6 m to support customer to access the web server
2nd router will connect to 2 deferent ISP with connection 8 m
To support the customer to access web server>>>>>>>>>>>>>>>>>.
I need to know if I configure VTP domain I need to know the maximum support client switches in this VTP domain >>>>>
1-I need to make load balance between to router
2- I need at lest 12 m to customer to access the web server
3- I need 2 m for user in internal network to can reache the internet
4- I need to configure 10 VLAN
I need solution for configuration
didyap Thu, 07/03/2008 - 05:20
  • Silver, 250 points or more
Load balancing are being different way as per which protocol you are using in your routing. Here is the some URL which will help you for load balancing purpose:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml#topic1
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml
For the configuration VLAN follow the URl:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_configuration_example09186a008009478e.shtml
