DASS -> ISDN30
Jun 27th, 2008
We are upgrading an old index PBX to Call Manager 6. The index PBX currently has circuits from 3 telco (BT, COLT, C&W) all 3 present these circuits as DASS. In order to move these over to an IOS gateway i understand we need to migrate from DASS. BT tell us that they will convert DASS to ISDN30 for us, will our gateways (2811 with VWIC2-1MFT-T1/E1) will this support ISDN30?
Overall Rating: 5 (1 ratings)
paolo bevilacqua Fri, 06/27/2008 - 02:58
  • Hall of Fame,
    Founding Member
Yes. Note you also need a minimum of a PVDM2-32 to support a full ISDN30 circuit.
You can check what you have in the router with "show diag".
Please rate post if it does!
iptuser55 Mon, 06/30/2008 - 01:06
  • Silver, 250 points or more
also bear in mind that with Euro ISDN at least with Colt you will lose the leading digit zero so you may need to re-insert again otherwise the CLI will look odd
