AS 5350 OID's
Jun 27th, 2008
Hello everyone who is reading this thread.
I need to monitor E1-channel load("sh isdn status" command - active layer 3 calls). Found the following OID:,Y-port). Have 2 AS installed:
1st: Board Hardware Version 2.6,Board Revision C1 with E1 2 PRI
2nd: Board Hardware Version 2.7,Board Revision B0 E1 4 PRI).
On the first AS I'm getting the correct Counter value, on the other AS i'm getting decreasing in time large number.Should I make a TAC request? (couldn't find with snmpwalk even close value I need)
Thank in advance.
