CWLMS 3.1 double proccesses
Jun 27th, 2008
When i check the the process status under Common services i can see a proccess "AdabterService" AND "AdabterService1", "DfmServer" AND "DfmServer1", "Interactor" and "Interactor1". Is this ok or is somthing wrong. I have one ethernet card enable on this server the other one is disabled. Also i think the machine is verry slow.
Martin Ermel Fri, 06/27/2008 - 03:06
These processes are ok. For some LMS processes a second instance was added with LMS 3.0 - I think this was done to split the load and get the performance needed when many devices are managed by the server. This has nothing to do with your NIC. If you feel the performance of the server is slow - check if you have meet the hardware requirements for LMS:
