2811- PVDMII-24D, login issue
Answered Question
Jun 27th, 2008
I'm trying to set up a 2811 as modempool with Dialout/Ez on the client. The problem is that the connection is terminated upon establishing the connection.
Sometimes it doesn't even show the login prompt to the remote RAS-server, and other times a login is possible and a few packets can be sent before it terminates.
Andreas
Correct Answer by Paolo Bevilacqua about 8 years 7 months ago
likely you do not have clock configured correctly, please configure:
network-clock-participate wic 0
network-clock-select 1 e1 0/0/0
Please rate post if it helps!
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Fri, 06/27/2008 - 04:45
AndreasJo Mon, 06/30/2008 - 23:27
Thanks, it did the trick and sorry for not RTM.
Kind Regards
Andreas
Paolo Bevilacqua Tue, 07/01/2008 - 02:49
Sometime the manual is not very useful in saying what is really needed and what is not.
Thanks for the appreciation and good luck.
