VPN Into Specific Subnetworks
Jun 27th, 2008
Hello All,
Im trying to set this up in my test environment before I tell a friend they can do this.
Lets say we have a router, 7204 w/ NPE-200.
FA0/0 is configured with a /28 from an ISP
FA1/0 is configured with multiple /24's for internal use (10.5.0.0/24 for example).
Each subnetwork (10.[1-5].0.0/24) has separate systems connected to the router for NAT translation, trunked over 802.1q into a switch, where that is transported over to servers.
We want to create a Remote Access scenario in which a user will be able to connect and their laptop/desktop will be assigned the correct subnetwork they are allowed access to. BUT if we cant do that, then we are ok with creating our own "VPN Subnetwork," where the user receives an address of 10.99.0.0/24 but comes in the question of locking down that specific user to networks (and possibly hosts) he should have access to.
Heres what I have been able to gather.
1) Local Authentication will work, but AFAIK you cant specifiy ACLs for specific users once they are connected?
2) RADIUS/TACACS/AAA maybe our best bet of customizing the per-user connections.
Let me know how I should approach this remote access scenario.
Israel
d-simic Thu, 07/31/2008 - 05:47
just a thought on point 1)Local Authentication
You can apply an ACLs to a group-policy, the group-policy to a connection profile and the connection profile or the group-policy to a local user:
username myuser attributes
vpn-group-policy mygrouppolicy
group-lock value myconnectionprofile
service-type remote-access
D.
