QoS Router and ASA differences
Answered Question
Jun 27th, 2008
Hi, I recently tested QoS over an IPSEC tunnel using and 876 and was able to limit effective input and output rates using QoS on the router between two hosts.
This got me thinking about trying it on an ASA. I have tried this on an ASA with no success, but it also says in the help it can only be applied to the "Output". Is there a difference in the QoS implementation between a router and ASA?
Update - I had got this to work but only when I use Any Any Traffic. If I select say 192.168.55.20 -> Any it doesn't rate limit.
access-list outside_mpc extended permit ip host 192.168.55.20 any
class-map ROB_QOS (Doesn't work)
match access-list outside_mpc
Class-map ROB_QOS (Does work)
match any
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
policy-map Rob_Policy
class ROB_QOS
police output 100000 2000 conform-action drop
service-policy global_policy global
service-policy Rob_Policy interface inside
service-policy Rob_Policy interface outside
Correct Answer by Farrukh Haroon about 8 years 11 months ago
Maybe its working now because you have NAT on this IP range 192.168.55.0 ? Are you employing any NAT for this subnet?
Farrukh
Overall Rating: 5 (1 ratings)
Farrukh Haroon Sun, 06/29/2008 - 00:38
  • Red, 2250 points or more
Yes, there are a lot of differences between ASA and ROUTER QOS.
As per CCO, on the ASA QoS policies when applied to the interface have specific direction, they apply only to the outbound traffic (with respect to the interface) where the service-policy has been applied. Have a look at this:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/mpc.html#wp1116522
However, one can apply 'police' in both output and input directions. This means that it can match the class-map in both directions (based on source/destination ports).
This is also a useful link:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008084de0c.shtml
Please rate helpful posts.
Farrukh
rasoftware Sun, 06/29/2008 - 05:02
Hi thats most helpful, I have followed the second article when I setup the test.
Policing works when I do "match any" but not when I use the ACL list. Is there something i'm missing here?
Partial confirm from above
If i "match any" it works.
Farrukh Haroon Sun, 06/29/2008 - 05:48
Try adding the following line:
access-list outside_mpc extended permit ip any host 192.168.55.20.
Farrukh
rasoftware Mon, 06/30/2008 - 01:18
Hi Farrukh,
I added the second line to the ACL but it still doesn't appear to rate limit.
I have attached the current config from the test ASA.
: Saved
ASA Version 7.2(3)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.55.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.150.60 255.255.255.0
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_access_in extended permit icmp any any
access-list outside_mpc extended permit ip host 192.168.55.21 any
access-list outside_mpc extended permit ip any host 192.168.55.21
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.150.5 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.55.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
console timeout 0
dhcpd dns 192.168.150.4
dhcpd lease 6000
dhcpd address 192.168.55.20-192.168.55.22 inside
dhcpd enable inside
class-map ROB_QOS
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
class ROB_QOS
police output 8000 2000 conform-action drop
prompt hostname context
Cryptochecksum:xxx
: end
Farrukh Haroon Mon, 06/30/2008 - 03:33
You have to add the "police input 8000 2000 conform-action drop " statement
Farrukh
rasoftware Mon, 06/30/2008 - 03:43
I have added this now but it still doesn't seem to control the rate. I have check my host IP also and this is correct.
class ROB_QOS
I also tried removing "output" but that had no affect.
rasoftware Mon, 06/30/2008 - 06:01
I have changed the service policy to the inside interface and it appears to work. I also applied police to input and output. It didn't seem to work without this.
This is a working 100Kb up/down throttle - does this look ok?
class-map ROB_QOS
class ROB_QOS
police input 100000 conform-action drop
access-list outside_mpc extended permit ip 192.168.55.0 255.255.255.0 any
access-list outside_mpc extended permit ip any 192.168.55.0 255.255.255.0
Correct Answer
Farrukh Haroon Mon, 06/30/2008 - 12:12
Farrukh
rasoftware Mon, 06/30/2008 - 12:43
Yes the connection is natted, i used a private on the outside as I have been testing it on our LAN.
It works a treat, able to rate limit multiple subnets from our 3550 switch and also timed based ACL lists on the limiting. Many thanks for your help.
