PROBLEM MPLS VPNV4
I have configured two non connected route reflector directly, but with connectivity.
I use OSPF like internal routing. And BGP for MPLS.
When I believe a vrf, it only leaves me for a RR, and if I throw RR I am fallen the vrf. I want that it leaves for two RR, to have redundacia for if a RR falls.
That I should add?
thank you
lee.reade Fri, 06/27/2008 - 06:26
  • Silver, 250 points or more
Sorry your explanation is not very clear, can you perhaps give us a diagram of the setup?
If you are asking how to have redundancy for PE's when one of two Route Refecfectors fail, then all you need to do have a BGP VPNV4 session to each RR from each PE.
If you give us more info, we can help you out!
Cheers,
LR
Sorry. You are right. I explain to myself well.
I have three ring as of the topology which attach you, and each one of the rings this connected to two 6500.
When I believe a vrf between two 2800 of two different rings, according to the configuration that I attach you, two RR should plunder, but only scamp one. I am almost sure that it is problem of BGP, but I am not sure.
I also attach you the config of the two 6500 of the ring.
thank you
