HWIC Slots
Answered Question
Jun 27th, 2008
a real easy one i guess, I have a 2811 with the HWIC 0 - 3 slots, can i put a vic2fxo in there? I was told you could but no joy at the moment :) ta guys
Correct Answer by Paolo Bevilacqua about 8 years 7 months ago
You are using a VIC-2FXO that not supported, as the router is telling you.
You need a VIC2-xFXO for the ISR routers.
As a recognition to whose providing answers, please rate useful posts!
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 06/27/2008 - 06:11
Yes, but you also need a voice image and a minimum of PVDM2-8 to process voice.
Please rate post if it helps!
hellspire69_2 Fri, 06/27/2008 - 06:21
I have a PVDM2-64 and c2800nm-spservicesk9-mz.124-3i.bin image is this not sufficient? Im a tad noob at this ;)
hellspire69_2 Fri, 06/27/2008 - 06:25
WIC Slot 0:
FXO Voice daughter card (2 port)
WIC module not supported/disabled in this slot
Hardware revision 1.1 Board revision J0
Serial number 27623997 Part number 800-02495-01
FRU Part Number VIC-2FXO=
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 0D 01 01 01 A5 82 3D 50 09 BF 01 00 00 00 00
0x30: 98 59 52 00 01 11 07 01 FF FF FF FF FF FF FF FF
Correct Answer
Paolo Bevilacqua Fri, 06/27/2008 - 06:29
