1812W->one dhcp->wifi+LAN
Jun 27th, 2008
hi there!
scenario same as here
http://cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805e7a23.shtml
but with LAN connected to the router too.
How do I do it with dhcp server on the router and wifi and LAN?
Purpose is to obtain address from DHCP to Wifi and also LAN.
my existing config is as below, but WiFi can't get IP address from DHCP server on the router...
vlan 1
authentication open
guest-mode
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp pool test1
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.253
domain-name ct.local
no ip bootp server
no ip domain lookup
ip domain name ct.local
ip name-server 62.87.178.194
ip name-server 10.0.0.4
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username nieca privilege 15 secret xxx
archive
log config
hidekeys
ip tcp synwait-time 10
interface Null0
no ip unreachables
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Dot11Radio0
no ip address
ssid cisco
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root access-point
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
ssid cisco
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio1.1
no cdp enable
bridge-group 1
interface Vlan1
ip address 192.168.0.253 255.255.255.0
no ip forward-protocol nd
Richard Burts Tue, 07/01/2008 - 10:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Grzegorz
If you want to have a single pool of addresses and have the router act as DHCP server using that single pool of addresses for both the wireless and the LAN then there are several things that you will need to change.
As currently configured the DHCP pool serves only the LAN, since the address is configured on the VLAN 1 interface and there is nothing to associate the wireless with that address space. So you will need to change this.
One way to think about it is that if the router will need to act as DHCP server for both the LAN and the wireless then they both need to be in the same broadcast domain (right now they form separate broadcast domains). So you should configure IRB as the easy way to put both the LAN and the wireless into the same broadcast domain.
Start with
bridge irb
bridge 1 route ip
Then in interface VLAN 1 remove the IP address and configure bridge-group 1. With bridge-group 1 on both the LAN and the wireless they will be in the same broadcast domain. Configure interface bvi 1 and assign the IP address to the BVI.
That should get both the LAN and the wireless into the same broadcast domain and allow the router to assign addresses from the same pool to end stations on the LAN and on the wireless.
Rick
tomaszpopik Wed, 10/29/2008 - 04:01
Thank you Rick, i have sucessfully configured 1812W following your advice.
LAN, WAN, WIFI, IP SLA.
