06-27-2008 06:30 AM - edited 03-05-2019 11:52 PM
Okay I'm running a wsc2950c-24 switch and a 3640 router from cisco. And I follow the instructions they have on their site and I just can't get this thing to work prooperly.
The computer on Vlan 1 has an ip of 192.168.4.100. The computer on vlan 85 has an ip of 192.168.5.101. I can't get 5.101 to ping anything on the switch. But on 4.100 I can get it to ping both router addresses and the switch address.
My config files are below:
Switch:
Using 2263 out of 32768 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname swtmw-em-test1
enable secret 5 XXXX
enable password XXXXX
ip subnet-zero
vtp domain XXXXX
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan 81
name johdoe
shutdown
interface FastEthernet0/1
switchport access vlan 81
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
switchport trunk allowed vlan 1-90
switchport mode trunk
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface Vlan1
ip address 192.168.4.253 255.255.255.0
no ip route-cache
interface Vlan81
no ip address
no ip route-cache
ip default-gateway 192.168.4.254
ip http server
banner login ^C kdkakfjakjdflkjasdlkfjakjdsfla C
dddddddddddddddddddddddddddddddddddddddddddddddddddddddddd^C
line con 0
line vty 0 4
password XXXXX
login
line vty 5 15
password XXXXX
login
end
router:
Using 1358 out of 129016 bytes
version 12.2
hostname rtrmw-em-test
enable secret 5 XXXXX
ip subnet-zero
no ip routing
interface FastEthernet1/0
no ip address
no ip route-cache
speed auto
half-duplex
no mop enabled
interface FastEthernet1/0.1
encapsulation dot1Q 1 native
ip address 192.168.4.254 255.255.255.0
no ip route-cache
interface FastEthernet1/0.2
encapsulation dot1Q 81
ip address 192.168.5.254 255.255.255.0
no ip route-cache
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
password XXXXX
login
end
06-27-2008 06:35 AM
"no ip routing "
Check your router config.....you should have "IP ROUTING" enabled
06-27-2008 06:36 AM
Can 192.168.5.101 ping 192.168.5.254 ?
Have you configured 192.168.5.101 with default gateway of 192.168.5.254 ?
What switchports are both machine using on the switch ?
I also see ip routing is disabled in the router, it must be enabled.
__
Edison.
