List of supported encryption or way for security CallManager inter-trunk
Dear All,
I have 4.2(3)sr1 clusters in severals places and I will need deploy trunk-intercluster(no-gk-controlled)through the WAN, then for me is mandatory a security interconnection, my question is what kind of type or form of encryption can I use for my inter-sites with this version of callmanager or I have to do an updgrade?, I know that into the enterprice parameters/Device Security Mode can leave encrypted, is it enough?
gogasca Fri, 06/27/2008 - 21:44
Hola Andres,
Unfortunately this option is not available for versions 4.X, but it is available for version 5.x,6.x and 7.x
Both clusters must be secure.
Trunk between the 2 clusters must be protected.
You can use ICT trunks which use IPSec.
SIP trunks can be protected through TLS
If you are using 4.x you may setup a GRE, IPSEc tunnel between those servers/Phones
