06-27-2008 06:49 AM - edited 03-11-2019 06:06 AM
Hi everyone,
The problem I'm having is that I have four configured interfaces. Two of them going to two different ISP's with two different networks configured. We can call them 10.10.1.0/24 and 10.10.2.0/24. The other two can be 192.168.1.0/24 and 192.168.2.0/24.
The default route is 10.10.1.1 going to ISP #1 and 192.168.1.0/24 is PAT'ed to 10.10.1.20
The problem is that I want to PAT 192.168.2.0/24 to 10.10.2.10 and send that traffic to 10.10.2.1, going to ISP #2.
How would I set this up?
Andreas
Solved! Go to Solution.
06-27-2008 10:01 AM
This is impossible with ASA, but possible with a router.
Only one possible way is to split your ASA in two context.
and associate 10.10.1.0/24 192.168.1.0/24 with first context and 10.10.2.0/24 192.168.2.0/24 with the second.
But is this case you will lose all vpn functionality.
06-27-2008 10:01 AM
06-30-2008 02:02 AM
Thanks for you answer, appreciate it.
07-02-2008 07:36 AM
Hi, We are freshers going through the article. We couldnt understand clearly your problem and the solution provided. Can u please explain the same.
07-02-2008 09:44 AM
PIX/ASA cannot do load balancing as a router do.
PIX/ASA cannot do policy based routing as a router do.
The problem is that Andreas wants to PAT 192.168.2.0/24 to 10.10.2.10 and send that traffic to 10.10.2.1, going to ISP #2.
How can we do this?
using two separated ASA (physicaly or logicaly)
the first - for ISP #1 and 192.168.1.0/24
the second - for ISP #2 and 192.168.2.0/24
If we use logical separation we use contexts on ASA.
