add user to acs 3.2 with csutil -i file
Jun 27th, 2008
I'd like to import to my acs a file for add user.
I don't know the parameter to use to define the CLI/DNIS-based access restriction.
Now I use the string
But I must to go to web console to restrict the access...
Can you help me? Or you can suggest a work-around?
Thanks in advance,
best regards,
darpotter Fri, 06/27/2008 - 12:54
You cant add NARs via csutil.
You can via RDBMS Sync.. tons of docs for that :)
