bcolvin Fri, 06/27/2008 - 11:23
  • Bronze, 100 points or more
Hector
A 1242 configured for bridging using the "A" radio and a single patch antenna for both the root and non-root will work. just mount the AP on the inside wall of the building and the antenna on the outside you should be able to connect the antenna to the AP using the pig tail on the patch antenna.
remember you nee clear line of sight and the antennaas need to line up.
Good Luck
Bill
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
