Doubt about Attendant Console
Jun 27th, 2008
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
Our Customer have a solution IP Telephony with CallManager 4.1.3 with configuration Attendant Console. In this morning my Customer have 05 branches and the call function Ok. In the evening our customer have only branch that is associated with service 0800. A First call is receiving normaly, but the second call in the branch go awaiting and the user not perceive that have the second call. This behavior is normal when using the Attendant Console because when we don't have Attendant Console we can configure the IP Phone for to attendant 02 call or more depend of model.
Thank You,
Best Regards,
Wilson
Jaime Valencia Fri, 06/27/2008 - 13:07
  • Cisco Employee,
  • Hall of Fame,
    2011
i'm not sure i'm following, exactly what do you want to achieve??
javalenc
wilsonsant Fri, 06/27/2008 - 16:39
Hi Javalenc,
My doubt is: when using attendant console, the single branch can to attendant more call without the second call stay in waiting, but, the user not to perceive?
Thank You,
Wilson
Jaime Valencia Fri, 06/27/2008 - 16:43
  • Cisco Employee,
  • Hall of Fame,
    2011
still don't understand what you want, can you try babelfish to translate your question??
if you wants more calls to be handled by the AC then you need to configure broadcast algorithm, that way calls will be put on hold while someone can answer it
you can configure the hunt group with the same user and several lines to handle more calls.
if you mean you want to transfer a call without a user being put on hold that is not possible
javalenc
if this helps, please rate
wilsonsant Fri, 06/27/2008 - 16:50
Hi Javalenc,
I will go to try the another way. Today in this afternoon our Customer have the only branch Ok. When this user receive this call he get to answer without problem, but, when the second call is did to go wait line and the user don't perceive that there are another call. Understand, now?
Thank You,
Wilson
