Found the Serial Number
Jun 27th, 2008
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
My customer lost the label the serial number CallManager. Is possible found the serial number by software callmanager?
Thank You,
Wilson
Jaime Valencia Fri, 06/27/2008 - 13:05
  • Cisco Employee,
  • Hall of Fame,
    2011
just a mouse scroll from your post:
CM 6.1 serial number
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc10df5
If it's not linux appliance then there is no way other than going to the server itself.
You might also find the information on the purchase order if bought from Cisco.
BTW, you can also use the search feature on NetPro, someone might have asked the same thing before
javalenc
if this helps, please rate
wilsonsant Fri, 06/27/2008 - 16:41
Hi Javalenc,
I am sorry, but, my customer have the CallManager version 4.1.3.
Thank You,
Wilson
Rob Huffman Fri, 06/27/2008 - 17:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
