Help with access list
Answered Question
Jun 27th, 2008
Is there an easier way to understand the wildcard mask when configuring ACLs? I hardly understand how to get the correct wcm.
Correct Answer by Jon Marshall about 8 years 9 months ago
Chris
Easiest way for me is to flip the bits from the normal subnet mask (sb) eg.
sb -> 255.255.255.0 = wcm -> 0.0.0.255
sb -> 255.255.0.0 = wcm -> 0.0.255.255
They are the easy ones, where there is a 255 in the sb make it a 0 for the wcm and where there is a 0 in the sb make it a 255 in the wcm.
To come up a wildcard mask for others eg.
sb -> 255.255.255.128 = wcm = 0.0.0.127
sb -> 255.255.255.192 = wcm = 0.0.0.63
sb -> 255.255.255.248 = wcm 0.0.0.7
quick way to work out - take the octet that isn't 255 and subtract it from 256 then subtract 1 ie.
256 - 192 = 64 - 1 = 63 so
wcm = 0.0.0.63
sb -> 255.255.224.0 =
256 - 224 = 32 - 1 = 31 so
wcm = 0.0.31.255
Hope that makes sense
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 06/27/2008 - 19:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Chris
wcm = 0.0.0.63
wcm = 0.0.31.255
Jon
chrisblaze Fri, 06/27/2008 - 20:25
Thanks that helps a lot, man this last book is a killer!
