SQL error when doing upgrade
Jun 27th, 2008
Hi Guys
I am upgrading from 4.03 to 5.0.1 but when i run setup it tells me i cant continue because the server name was changed and thats a problem for sql .
As far as i no the name has always been the same .
Is there a easy way out of this or am i in for a reinstall .
I need to upgrade because of exchange 2007 and would like the least impact for the users.
eschulz Fri, 06/27/2008 - 22:44
Could be CSCsj92828?
If not, when you're checking on that, verify the @@ServerName in SQL is what you expect. If not, you _might_ be able to move forward by changing it. Otherwise, you might be in for that reinstall.
-Eric
tonygray1 Thu, 07/03/2008 - 21:43
Everything checks out and even going by the log it does but it fails . Think E7 unified messaging is looking betta all the time .
IsServerRenamedBefore Test Started. (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1096)
2008-07-04T11:59:37 - ...Server Rename Test: - weeklybackupjobs check - PASSED.. (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1163)
2008-07-04T11:59:37 - ...Default location=Default741e319f - HomeServer=WA-VM2 (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1236)
2008-07-04T11:59:37 - ...Server Rename Test: Unity default location home server name not match with local machine NetBios name.. (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1241)
2008-07-04T11:59:37 - ...DataStore server name=WA-VM2 (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1268)
2008-07-04T11:59:37 - ...Server Rename Test: DataStore server has been renamed.. (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1273)
2008-07-04T11:59:37 - IsServerRenamedBefore Test Ended. (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1098)
2008-07-04T11:59:41 - Mode:Install, Step:FailedStep [IDD_FAILED] (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\MYSETUP.CPP 252)
