Cisco 2801 as gateway and Nortel gatekeeper
Jun 27th, 2008
I have this scenario, one 2801 with a T1 wic, and one nortel signaling server as gatekeeper, the calls are connect but i don't get audio.
CSCO10655862 Sat, 06/28/2008 - 04:39
yes, currently are communications between the gatekeeper and the cisco gateway. The problem is the audio, i can't hear anything in both ways.
Paolo Bevilacqua Sat, 06/28/2008 - 04:41
Hi, GK doesn't take part in media, only signalling.
You need IP connectivity between GWs for a GW/GK setup to work.
Paolo Bevilacqua Sat, 06/28/2008 - 05:21
Yes, I understood that. The point is that you also need IP connectivity to the other GW that is terminating the call. Unless the GK is actually combined GK/GW.
