CM5.1 ccmadmin page loading extremely slow
Jun 28th, 2008
When I access my CCM5.1 publisher's ccmadmin page, it is loading very slowly (30 mins) to load one page.
Sometimes I can log in without any delay, however when I select eg. a device pool, it will hang and i have to wait for a very long time again for it to load up the page.
Any suggestion?
Jaime Valencia Sat, 06/28/2008 - 08:39
have you tried restarting the tomcat and AciscoDB services?
if this helps, please rate
mattcalderon Sat, 06/28/2008 - 13:51
If you are using DNS servers, verify they are up and you have access to them. I have seen where DNS servers that are configured in call manager but can not be reached for some reason cause this issue. You can ssh in to the call manager and verify your DNS config. Look at the command net utils.
Chad Stachowicz Sat, 06/28/2008 - 15:11
How big is the database (how many phones?) I have a few systems on 5.1 with only like 2000 phones that ran slow as heck until I recently remediated the entire dial-plan...
lawrencekjoseph Sat, 06/28/2008 - 21:31
please check which applications are running in the server and which aplication tooks more cpu .please update the antivirus and scan .
i think it will solve your issue.
Chad Stachowicz Sat, 06/28/2008 - 23:29
anti-virus and scan a cm5.1? no root access? Maybe your mistaken this from a conversation about 4.x?
Jaime Valencia Sun, 06/29/2008 - 10:12
well, you can indeed check the services that are hogging up the CPU but anti-virus and scan cannot be options since linux appliances do not have those (and if by any chance someone got root access and installed anything else it won't be supported). anyway it might be a good idea to check the iowait on the server.
esther.tan Mon, 06/30/2008 - 00:50
A TAC engineer had assist to check. Found that the db is not correctly updated when we removed a server from the publisher previously. We can still see the "deleted" server from the publisher's database. This in turn caused replication problem.
After the db is updated by TAC using root access, the page loads fine.
Thanks guys for all the advice given.
