Chris Deren Sat, 06/28/2008 - 03:15
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
For all of them.
Chris
Jaime Valencia Sat, 06/28/2008 - 08:39
  • Cisco Employee,
  • Hall of Fame,
    2011
As Chris mentions, there is no limitation on the amount of phones you can assign to one partition. just consider that if you have it all in one partition that could cause CUCM to take some more time because the digit analysis will have a lot more of choices if your dial plan is not unique and has overlapping.
javalenc
if this helps, please rate
