WCS + 2 x WLC 4402 x 25 AP = ?
Answered Question
Jun 28th, 2008
Is it possible to use WCS + 2 WLC 4402 with 25 APs license to control 50 APs?
Thanx!
Correct Answer by Rob Huffman about 9 years 3 weeks ago
Hi Mikhail,
Yes, this config is perfectly acceptable and will support 50 AP's :) It will not support any futre growth as far as adding additional AP's (without adding a new WLC)You also might want a third WLC to be used in an N+1 Topology in case of a WLC failure.
But other than that you should be good to go.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Sat, 06/28/2008 - 11:10
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Mikhail,
Hope this helps!
Rob
m.sobolev Sat, 06/28/2008 - 11:13
Thank you :) WiFi is not critical for us, we just need some more APs and fortunately have second 4402 :)
