steven2000 Tue, 07/01/2008 - 06:11
hi Sean
I wrote and passed the 901 exam two weeks ago. Its very important for you to always save your config (issue the copy run start)both in real life and exams.
If you use a command that is not applicable to that simulations, a pop up will tell you that the commmand is not usable in that sim.
I can safely advice you to always do the copy run start during the exam(s).
I hope I've answered your question.
All the best.
ps rate it
steven2000 Tue, 07/01/2008 - 06:13
hi Sean
I wrote and passed the 901 exam two weeks ago. Its very important for you to always save your config (issue the copy run start) both in real life and exams.
If you use a command that is not applicable to that simulation(s), a pop up will tell you that the commmand is not usable in that sim.
All the best.
ps rate it
