Same route-pattern
Jun 28th, 2008
is it possible to have same route pattern(9.xxxxxxx) for two gateway (one in the HQ other in remote site) using SRST.
I mean any extension in the HQ dial 9.xxxxxxx will go PSTN through local gateway and the remote will also dial 9.xxxxxx to get to loacl PSTN.
Overall Rating: 4 (1 ratings)
Chad Stachowicz Sat, 06/28/2008 - 16:22
of course! give each site their own CSS, with access to the internal Partition + the site specific Partition containing the local 9.xxxxxxxxxx pointing to the correct gateway!
9.xxxxxxxxxx / pt-sitea -> RL-SITEA
9.xxxxxxxxxx / pt-siteb -> RL-SITEB
css-sitea / pt-internal
css-siteb / pt-internal
RL-SITEA -> HQ gateway
RL-SITEB -> remote SRST GW
HTH, please rate useful posts..
Jaime Valencia Sun, 06/29/2008 - 10:07
just as a side note from the great info from Chad make sure you do not have both partitions on the same CSS because that will cause the partition that is higher on the CSS to be selected over the other one.
this kind of configuration can also be used for toll-bypass in case you want it.
if this helps, please rate
