Problem with my cisco 871-k9-advsecurity
Jun 29th, 2008
Hello everybody
i'm actually configure a router cisco 871.
My objectives:
- access to internet
- Create a VPN Site to Site
for the internet connection all is ok
no more problem.
But i have a serios problem with my VPN. I created a VPN-Site-to-Site between this router and Netasq F200. VPN is working but when i want to ping form computer behing my cisco, all is ok i can ping which is my netasq address, i can ping server (
but if i want to make a 2048 bytes ping on the netasq i can but if i make
ping -l 2048 (the server) i can't i don't have any answer. But i used ethereal on server i see icmp incoming form my computer on the netasq i see the answer which come to the cisco but i don't have any answer on my computer. On ethereal i see that there are fragments i tryed to modify MSS (cause i can't modify MTU) but there were no effect.
Please i need to make ping with 2048 bytes it's for GPO (Windows) I attach config file. I hope u'll help me.
mathduvar Sun, 06/29/2008 - 06:59
i already reduced mtu but no way
i cant make ping with 2048 byte on the distant router and it's working but not server behind this router
a little diagram :
IPSec tunnel
Server - - - - ROUTER - - - - - - ROUTER CISCO 871 NETASQ F200
and behind router i have another server :
if i ping (2048) from to it's ok
if i ping (2048) from to no answer
if i ping (normal) form to it's ok
it's same if i ping from to
i don't understand
