Called Party Transformation
Jun 29th, 2008
Some immediate help would be appreciated!
What I have is a CTI Port say ext. 5000
This is forwarding to a route point 7000.
In the route list I am sending it over a qsiq trunk.
Whenever I dial 5000, 7000 is presented as the called number.
I need to have 5000 presented as the called number.
Any help is appreciated.
Chad Stachowicz Sun, 06/29/2008 - 14:55
  • Silver, 250 points or more
Why are you doing it this way? Make sure what calling device you using to call 5000 has a Calling Search Space on the devices that has access to a partition containing a Route Pattern as 5000 with RL -> QSIG. The forwarding sounds unnecessary ?
HTH please share more if I'm missing something..
Chad
roboliveira Sun, 06/29/2008 - 15:15
The 5000 is a user DID that comes in over PRI. Wen that call comes in I need to send it over the QSIG to a siemens remote shelf.
If there is an easier way to do this I am open to any ideas.
Chad Stachowicz Sun, 06/29/2008 - 15:38
ahh this is no problem..
Create a Partition
PT-Gateway-To-QSIG
then in the gateway CSS on the incoming PRI, make sure that Incoming CSS contains this partition in it).
now make 5000/PT-Gateway-To-QSIG Route Pattern and point it to RL-QSIG..
HTH, Please rate useful posts
Chad
PS/ (Be careful not to make a routing loop in the gateway, always double check Gateway CSS..)
