1310 Bridge Associated but cannot send/receive data
Jun 29th, 2008
Hi everyone,
I've just setup in my office a pair of 1310 with external antennas and I'm trying to test the link by pinging the other side from each bridge, but it seems like it's failing as I can't get any data through the link.
I've doublechecked my configuration and everything seems ok.
Below is the configuration:
Root Bridge:
version 12.4
no service pad
service password-encryption
hostname root
enable secret xxx
no aaa new-model
dot11 ssid ip-mon
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 12345
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid ip-mon
speed basic-1.0 basic-2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
packet max-retries 3 0 fail-threshold 100 500 priority 5 drop-packet
packet max-retries 3 0 fail-threshold 100 500 priority 6 drop-packet
no preamble-short
channel 2472
station-role root bridge
beacon dtim-period 10
world-mode dot11d country GR both
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.10.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.1
ip http server
ip http authentication local
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community community RO
bridge 1 route ip
line con 0
login local
line vty 0 4
login local
end
Non-Root Bridge:
version 12.4
no service pad
hostname non-root
enable secret xxx
no aaa new-model
dot11 ssid ip-mon
authentication open
guest-mode
infrastructure-ssid optional
bridge irb
no ip address
no ip route-cache
ssid ip-mon
no preamble-short
channel 2472
station-role non-root bridge
bridge-group 1
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.10.3 255.255.255.0
no ip route-cache
ip http server
bridge 1 route ip
line con 0
login local
line vty 0 4
login local
end
Any help or suggestions are welcome.
Thank you
Overall Rating: 3 (2 ratings)
bcolvin Tue, 07/01/2008 - 17:59
  • Bronze, 100 points or more
Chris
Please reference this document on how to configure you AP's
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml#config_ap2
The one difference i noticed was you do not have Key management set to mandatory.
one other suggedstion use the GUI interface as shown in the examples and all your bride groups will have the proper entries.
you did not mention vlans definatly use the GUI to configure them
Bill
cpartsenidis Wed, 07/02/2008 - 02:10
bcolvin ,
Many thanks for your input.
I'd much prefer if it was possible to identify the problem with my configuration, rather than re-programming the APs via the GUI interface. I'm not a particular GUI fan or users, so I'd really appreciate any input on the posted configuration.
I'm sure it wouldn't be too hard to spot the misconfiguration.
Thanks mate,
bcolvin Wed, 07/02/2008 - 19:06
I understand your reluctance to use the GUI to configure the AP but having worked with this product since it ran on VXWorks the GUI is the way to go because the CLI documentation falls a little short on this product when it comes to configuring anythisn but the IP address and WEP encryption. That is why I always reccommend using the the GUI for these configurations. With the GUI you can eaisly save the config file and reapply it to an AP, also as it is saved as a .txt file you can edit it to your hearts content in notepad or telnet to the AP and use the CLI to edit it in place.
I have seen to many config errors when the CLI is used when 5 minutes with the GUI resulted in a working AP.
I know the GUI works give it a try and check the resulting config file.
I'll get off my soap box
good day
Bill
srosenthal Mon, 07/14/2008 - 06:51
You noted that you are using 1310 with external antenna's. I noticed that neither or your configs show which antenna port (right or left) you are using. The 1310G-A-K9-R is the model with external antenna connections. If you are using a 1310G-A-K9 is being used, then this is an internal antenna unit only with no connections for external antenna's.
What is the distance between bridges and what antenna's are you using?
cpartsenidis Mon, 07/14/2008 - 09:29
Thanks for your post.
The issue has been resolved. I attached two small antennas to the bridge units and after the two sides associated with each other, I was able to ping across.
Is there any way I can check the actual speed the bridge has ?
Many thanks.
srosenthal Wed, 07/16/2008 - 04:21
You can view the statistics of the radio interface. That will show you detail of what speeds the packets are being sent at. If you have a 54M connection then the majority of your packets should show at 54M.
