Forwarding multiple overlaid lines using softkey?
Jun 29th, 2008
Hi all,
A customer wishes to be able to forward incoming calls to different voice mail boxes at different times of the day.
Is there any way to do this using night-service (a time range determines where call-forward night-service goes?)
I tried manually forwarding to the mailbox. However, the problem is that the number in question is assigned to multiple ephone-dn entries that are overlaid. Using the CFwdAll softkey only seems to forward one of the lines - or possibly it thinks that the forward is established but it doesn't work.
Should this work, or is there a better way to achieve this?
Williams_Tyson Thu, 07/03/2008 - 18:22
FWIW I didn't find a good solution to this. Instead, I wrote an ASP page that telnets into the router, does a conf t, and reconfigures all of the ephone-dns.
Anyone know if it's possible to set call forwarding using SNMP? I worked out how to retrieve the current forwarding setup, but that bit was read only.
