error when insering a new IP Phone on CUSM 6.0(1)
Answered Question
Jun 30th, 2008
Hi dear,
I've got an error when i tried to inser a new phone in CUSM 6.0(1)..The error message is in the attached...
Maybe it's about licensing that needs to be validate on Cisco Web site, right?
Thanks in advance
Cheers
Correct Answer by Rob Huffman about 8 years 8 months ago
Hi Mohamed,
You bet my friend. Once the "Permanent" licenses have been loaded this error will disappear and you will be ready to go!
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 06/30/2008 - 04:58
Hi Mohamed,
Yes, you are most correct! This error does reflect a Licensing issue. Have you uploaded all the required licenses? Is this a lab or production box? Is this a migration from CCM 4.x to 6.x?
Rob
mferhai Mon, 06/30/2008 - 05:02
Hi Rob,
This is a production box...a new installation.
No, i didn't upload the required licenses...Should i request the required license using my PAK on http://www.cisco.com/go/license ?
Thanks to advise.
Cheers
Mohamed
Correct Answer
Rob Huffman Mon, 06/30/2008 - 05:15
Hi Mohamed,
Hope this helps!
Rob
