06-30-2008 02:07 AM - edited 03-05-2019 11:53 PM
I have an issue with spanning a port on the switch. Please assist.
I have a switch of 4510R-E series with port 8/47 providing MAN lin kconnectivity to another office. I see the tx or rx load on the interface to be hitting 250 every 1 min or so. I would want to trace the traffic on this link. So, I thoght of spanning the traffic onto a system & analyze. th eport 8/47 is on VLAN 250. I configured the below:
monitor session 2 source vlan 250
monitor session 2 destination interface fa 8/11
I have my local system connected to fa 8/11 on the same switch. When I configure the span this way, I lose connectivity to the system on 8/11. The moment I remove the configurtaion, I am able to ping to the system & access the system. Why is this so?
How do I proceed with this ?
06-30-2008 03:19 AM
This is because the SPAN sets the port to only forward SPAN traffic. (the traffic to your sniffer/analyzer)
The SPAN port disables the forwarding of non SPAN traffic; any traffic from your PC, so the PC connectivity is in essence lost while the SPAN is in effect.
Utilize your sniffer/analyzer while the SPAN is in effect and it will capture all the traffic the SPAN sends to port 8/11.
Please see the following link for more SPAN info:
Characteristics of a SPAN Destination port:
07-01-2008 03:35 AM
The best way to do this is that there should be two ethernet cards on the system -
- one card will be in promiscous mode , collecting all traffic from the SPAN port on the switch for analysing/sniffing traffic.
- the other card will be operating normally for network access.
07-01-2008 03:39 AM
Suppose you have eth0 and eth1 on your system,
then
eth0 - (promiscous mode) - configure tools like Wireshark/Ethrreal to sniff traffic on this port. Connect this to the 8/47 port as in your case.
Eth1 - (access mode) - for your system to acces s network, connect this to the normal user VLAN port on the switch.
Rate if helpful.
dhananjoy
