06-30-2008 02:53 AM - edited 07-03-2021 04:05 PM
I have configured 3 DHCP scopes and one WLAN. As I don't see any clear option, can you explain how to bind a particular scope to a WLAN?
06-30-2008 06:29 AM
You need to make sure your wlan ssid is mapped to one of the subnets in which you created a DHCP scope.
07-11-2008 05:06 PM
On the Dynamic interface that you assign to the WLAN you need to make sure you have the DHCP Server IP address as the MGMT interface of the controller. Clients that associate to that SSID will then get an IP address that is in the same network as that dynamic interface.
