PIX 8.0 net static em_limit
Jun 30th, 2008
I have a single net static for 120 dmz servers with no max_conns or em_limit set.
Can anyone confirm whether values I set on the net static will apply to each host, or to the combined traffic for all hosts? I plan to replace with separate statics for each host so I can have different thresholds, but I need a quick fix until then.
Also, is TCP Intercept enabled by default, or do I need a bunch of MPF stuff?
KeithR
nomair_83 Mon, 06/30/2008 - 03:27
  • Bronze, 100 points or more
Dear It will set to the combined traffice for all hosts.
no , tcp intercept is not enabled by default.
but you can configure with nat statement as well..(IF u dont like MPF)
