Trouble with ipseс vpn
Jun 30th, 2008
At first i configure my asa 5520 8.0 to vpn with 3des encryption but now i want aes encryption
When i set new crypto isakmp policy & transform-set it's not working and i see in debug this:
IKEv1]: Group = x.x.x.x, IP = x.x.x.x, QM FSM error (P2 struct &0x49ba5a0, mess id 0xcd600011)!
[IKEv1]: Group = x.x.x.x, IP = x.x.x.x, Removing peer from correlator table failed, no match!
what is wrong?
nomair_83 Mon, 06/30/2008 - 04:29
  • Bronze, 100 points or more
Dear just remove the crypto map on interface and no crypto dynamic-map outside_dyn_map 100 set pfs with no crypto isakmp enable outside.
then type:
crypto map mymap 70000 ipsec-isakmp dynamic outside_dyn_map.
let see it works else check the remote site if AES is supported or not.
srue Mon, 06/30/2008 - 04:46
  • Blue, 1500 points or more
try using group 2 in the isakmp policy. are you using certificate authentication or not?
srue Mon, 06/30/2008 - 06:00
did you try using group 2?
kaachary Mon, 06/30/2008 - 09:09
  • Cisco Employee,
Looks like AES is not enabled on the remote site. If you do the changes here, make sure the similar changes are done on the remote vpn endpoint.
