SNMP info from "Outside" interface on ASA suddenly stopped today
Jun 30th, 2008
I can get SNMP info from all of the interfaces on my ASA except the "Outside" interface. It's been working fine for months until a couple of hours ago, what can I do?
Farrukh Haroon Tue, 07/01/2008 - 00:00
You mean you are polling 'using' the outside interface IP or in your NMS you can't see any data for your outside interface?
whiteford Tue, 07/01/2008 - 02:48
Hi Farrukh,
Internally from my SNMP server (Solarwinds) I am connecting to the Outside interface. It connects and I usually poll it every 3 seconds to update me on the Internet bandwidth. It seems it only works if I set the poll to more than 10 seconds now.
Farrukh Haroon Tue, 07/01/2008 - 03:17
I would do the following:
1) Check the ASA via a free tool like GETIF.
2) Check the CPU/Memory resources on the ASA.
3) Do the same for the Solarwindws Box.
4) Try to re-add the device in Solarwinds.
