NAT as Port Forwarding?
Jun 30th, 2008
I'm very familiar with forwarding ports on Linksys routers, but they kept dying so I bought a bunch of Cisco 851 routers and can't figure out how to forward ports.
It should be simple, any outside IP should hit port 80 of a computer on the network.
How does one set this up when there is now port forwarding options?
Collin Clark Mon, 06/30/2008 - 06:53
  • Purple, 4500 points or more
ip nat inside source static tcp [private IP] 80 interface [or public IP] 80
You'll also have to allow access via an ACL.
Hope that helps.
