CUCM 6.0 - Timing call control
Jun 30th, 2008
  • Bronze, 100 points or more
Hi guys, I'm configuring different restrictions for calls in CUCM 6.0. Does anyone know how to configure calls with timing control? I mean, I want to control the duration of a call to the PSTN (for example: a maximun of 5 minutes), after this time the call should be terminated.
Is it possible to get that level of control?
Thanks a lot
Best regards
David
Overall Rating: 3 (1 ratings)
Michael Owuor Mon, 06/30/2008 - 07:16
  • Cisco Employee,
Hi David,
There is a clusterwide Service Parameter that may do what you want:
Maximum Call Duration Timer: This parameter specifies the minutes that a call can remain active before Cisco CallManager clears it. A value of zero disables the timer.
Default: 720
Minimum: 0
Maximum: 35791
Unit: min
Steps to configure:
Step 1 - In CallManager Administration, select System > Service Parameters.
Step 2 - In the Server drop-down list, choose a server.
Step 3 - In the Service drop-down list, choose Cisco CallManager. The Service Parameters Configuration window appears.
Step 4 - In the Clusterwide Parameters section, specify a Maximum Call Duration Timer setting.
Hope this helps.
Michael.
david-lima Mon, 06/30/2008 - 10:35
Great option, thanks Michael. Just this one: Is there a way to define a different call duration timer for each IP Phone?
Thanks again
David
Michael Owuor Mon, 06/30/2008 - 10:48
  • Cisco Employee,
Hi David,
The answer, unfortunately, is no. Today, the parameter applies cluster wide only, so to all phones in the cluster. You might contact your account team for help with getting a feature request submitted, if its not already on the roadmap.
Hope this helps.
Michael.
