OCS 07 RCC Integration
Jun 30th, 2008
I'm currently using OCS 2007 Std with an Edge and Mediation. It's integrated with Cisco Cucm 6.1.1 and CUPS 6.0.2 with RCC
On Cucm I've configured a Sip Trunk to Mediation server
This integration is working fine. My question is how will communicator (configured for RCC) work when I'm remote.
I'll use myself as an example: I have a desktop at work running communicator, and a 7945 phone on my desk (with RCC); I also use a laptop at home or out of office running communicator. If I'm at home, I want to be able to call a pstn user by communicator using it as a device (not RCC when I'm out of office).
But it seams not working.
What's difference between RCC and Enterprise Voice + PBX integration ?
mmcgille Mon, 07/07/2008 - 10:54
Communicator won't be able to control your phone when you aren't on the corporate LAN (which makes sense - it wouldn't do you any good to use your work phone from your home).
And unfortunately you can only choose RCC or Enterprise Voice with the OCS-CUPS integration. Cisco/Micorsoft don't support the EV+PBC integration option right now.
So you can't flip between RCC when at work and EV when at home. Crummy limitation.
Hope that helps.
