6500 redundancy with VSS
Jun 30th, 2008
If you have a pair of 6500's running VSS with your VSL link on a seprate line card not the sup engines can you pull out the standby supervisor and continue to pass traffic on the switch with the pulled sup?
scwillis4655 Tue, 07/22/2008 - 05:07
According to the link you gave, if you lose the standby sup you lose the standby switch interfaces. So no traffic passes through the stanby switch, or am I reading that wrong.
a.alekseev Tue, 07/22/2008 - 05:21
  • Gold, 750 points or more
No, you cannot.
You must have 2 sups for VSS to work.
If you pull out the standby supervisor from the chassis, this part of the VSS switch will stop forwarding traffic.
