CSS and a Sorry Server
joecunningham
I have been trying to get my CSS 11506 to redirct to a Sorry Server when our content servers go offline. We thought that we had it working, but after some downtime it turned out that our configuration did not work.
After extensive reading I can't figure out what is wrong with my config, or if the problem lies else where. I am attaching my config below, can anyone tell me if they see any problems with what I have or if there is something that I need to do in addition to what I have. Thank you for you help, here is the config:
*************************** GLOBAL ***************************
no restrict web-mgmt
no restrict xml
bypass persistence disable
snmp community ******read-write
snmp name "******"
snmp contact "*******r"
snmp location "CSS11056"
snmp trap-host 10.20.1.4 ******
dns primary 10.20.1.2
ftp-record ******10.20.1.17 *** des-password
ibfebcgg6aheuc4h1hfcqhpcubwdxcjb cssgui
ip route 0.0.0.0 0.0.0.0 10.20.1.1 1 !
*************************INTERFACE*************************
interface 1/1
phy 1Gbits-FD-sym !
**************************CIRCUIT**************************
circuit VLAN1
router-discovery lifetime 1000
ip address 10.20.1.4 255.255.255.0
router-discovery
**************************SERVICE**************************
service Blade01
ip address 10.20.1.60
active
service Blade02
ip address 10.20.1.61
active
service Blade03
ip address 10.20.1.62
active
service Blade04
ip address 10.20.1.63
active
service sorry
ip address 10.20.1.41
active
!*************************** OWNER***************************
owner ***
email-address ******
content Content1
vip address 10.20.1.80
balance aca
add service Blade01
add service Blade02
no persistent
primarySorryServer sorry
active
content Content2
vip address 10.20.1.81
add service Blade03
add service Blade04
balance aca
active
!*************************** GROUP***************************
group content1nat
add destination service Blade01
add destination service Blade02
add destination service sorry
group content2nat
add destination service Blade03
add destination service Blade04
!**************************** ACL ****************************
acl 10
clause 5 permit any 10.20.1.60 destination content ****
sourcegroup ****
clause 6 permit any 10.20.1.61 destination content ICC/flippid
sourcegroup Content1
clause 99 permit any any destination any
clause 2 permit any 10.0.0.0 destination content ****
sourcegroup ****
apply circuit-(VLAN1)
clause 7 permit any 10.20.1.41 destination content ****
Gregory Scarlett
One problem I can see is that you don't have any keepalives configured under the services, so they will default to a Ping. As long as they respond to ping, it will keep traffic going to those servers.
What services run on these Servers? We generally recommend you use as higher layer keepalive as possible, so if it is a web server for example, use a HTTP keepalive.
Have a look here for more info:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.10/configuration/content_lb/guide/KAL.html
