10/100 Ports on SOHO91
Jun 30th, 2008
Does anyone know if it's possible to access and/or configure the four 10/100 ports on a SOHO 91 router? IOS shows only E0 and E1 interfaces. I'm trying to see if there is some way to force one of the 10/100 LAN ports to 10 MB/s fixed.
However, it looks like the unit just has an internal "dumb" hub or switch (not sure which) that has an internal connection to E0. THANKS!
andrew.butterworth Mon, 06/30/2008 - 10:24
The SOHO 91 is effectively the same hardware as an 831, however the software is stripped back. With an 831 you can individually configure the 10/100 Ethernet ports (speed, duplex & switchport settings). Unfortunately with the SOHO 9x series this functionality has been removed and you can't configure the physical characteristics of the four 10/100 Ethernet ports.
Andy
mikez Mon, 06/30/2008 - 13:15
That's what I was afraid of. I appreciate your reply. THANKS
