CUCM Cannot Update Phones
Answered Question
Jun 30th, 2008
I have been running CUCM 6.1.1.3000-2 for about a month now, and ran into the problem today that any updates that I make to phones will not take effect.
In addition, when I delete a phone, and go as far as a hardware reset (hold down # on startup) the phone will still register as normal.
Phones are registering fine, and are functioning, I just cannot make a change.
I have restarted tftp, and dbl. This is a single server deployment, so all the phones are registered to the only PUB.
What else should I look at?
Correct Answer by Jaime Valencia about 8 years 12 months ago
we restarted RIS, DBL, ACISCODB and TOMCAT. at the time the guy was not willing to restart CCM, so that's the only one we could not try. later on during the night he rebooted the server but the traces were not enabled so we could not get a root cause
you can try those services, maybe with you they do the trick
javalenc
if this helps, please rate
Overall Rating: 4 (3 ratings)
Jaime Valencia Mon, 06/30/2008 - 11:29
  • Cisco Employee,
  • Hall of Fame,
    2011
i saw a similar issue like this on which the GUI would show the changes but the DB would not change (we confirmed what was on the trace using QRYs in the DB directly and they matched), a reboot cleared the issue
javalenc
jeff.heckart Mon, 06/30/2008 - 12:00
Jaime,
Thanks for the response. I was afraid of that.
Did you try restarting other services? I would like to avoid a reboot as this is a single ccm deployment, but if that's the only option, I'll give it a shot.
Jeff
Correct Answer
Jaime Valencia Mon, 06/30/2008 - 12:05
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
jeff.heckart Mon, 06/30/2008 - 17:03
I went ahead and rebooted. I wish I knew of another way to handle it, should it come up again, but it least that resolved it this time.
ogden.clinic Mon, 07/28/2008 - 14:45
We're on 6.1.1.2000-3 here and are seeing the issue today (I spent the whole day thinking I was finally losing my mind). Did anybody find a root cause or service that can be restarted as opposed to the whole server? Is there an open bug on this?
Tx.
Jaime Valencia Tue, 07/29/2008 - 06:08
  • Cisco Employee,
  • Hall of Fame,
    2011
i believe so far no one has had a TAC case and provided all the info to review so no bugs for this
java
