06-30-2008 10:52 AM - edited 03-14-2019 02:28 AM
Is it possible to extract data from the IPCC SQL database, and to use this data to make some customized reporting?
I have IPCC standard.
Bye,
JH
06-30-2008 01:37 PM
Absolutely. What version of Express are you running?
06-30-2008 10:40 PM
IPCC 4.5 standard
07-01-2008 04:57 AM
Below is the link to the Database Schema for 4.5(1)...
07-01-2008 06:18 AM
Thanks Joe,
How do actually connect to the IPCC? It is not SQl, but MSDE. How would you connect to this database?
JH
07-01-2008 09:09 AM
I have the exact same question. Ive already downloaded the schema just need to know how too connect.
SF
07-02-2008 12:28 AM
You need IPCC Express Premium to use database connectors in your scripts.
If you only need extracting data to do reporting, the MSDE instance is running under Server_IP\CRSSQL. You can create an ODBC connection to access the database.
You can also use Crystal Reports to integrate the new customized reports with the CRS Historical Reporting Tool.
Carlos
07-03-2008 01:38 AM
Thank you all, made it work. I installed enterprise manager on the IPCC created the user I wanted to use to connect. And now we have access and can extract the information we want.
JH
09-07-2008 03:25 AM
can you tell us which enterpise did you install ?
09-07-2008 05:27 AM
IPCC 4.x uses Microsoft SQL 2000 (MSDE) if you haven't purchased the Cisco SKU for full SQL Server.
09-09-2008 01:01 AM
SQL 2000 enterprise manager
JH
